check engine light
Old Apr 22, 2008 | 08:52 PM
camaromuscle89's Avatar
check engine light
ok here is my problem i just put a 350 tbi in my 89 camaro v8 305 tbi its been running ruff beacuse the timming was off and it had a vacuume leak well it just got fixed it started up but the timming was still a little off welll i went back to start it up now it wont start when i turn the key to the on position i have no check engine light??? why dont i have a check engine light please anyone help me out im am now stuck thank you
Old Apr 23, 2008 | 07:41 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: check engine light
SES bulb burned out? Fuse popped? There is a hidden fuse in the power feed under the hood. In line along the passenger side fender is a heavy wire. Near the front (battery) is a fuse in line with it. That feeds the ECM & fuel pump. Does the fuel pump run at key-on, engine-off for 2 seconds?
RBob.
Old Apr 23, 2008 | 06:25 PM
i turn the key to the on positon and nothing happens no check engine light comes on no fuel pump either
Old Apr 24, 2008 | 07:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Good possibility it is the fuse in line with the wire. It feeds the fuel pump & ECM.
RBob.
Old Apr 24, 2008 | 09:28 PM
ok you were right thank you and one more question how do you correctly time a car
Old Apr 25, 2008 | 07:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Warm the engine up first. Then shut off and connect a timing light to cylinder #1 (front left (drivers) side). May need to clean timing tab & damper to be able to see the marks.
Disconnect EST/BYPASS connector (right side near firewall, single wire with connector, tan with black stripe).
Start engine, get it to idle (it won't want to at first).
Read timing on damper with light and rotate distributor to 0 BTDC (for L03 TBI cars). Tighten distributor bolt, double check timing still at 0 BTDC.
Turn off engine, reconnect EST/BYPASS connector. Remove timing light, close hood.
RBob.
Wade787b
Sep 29, 2015 01:15 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Omega
Aug 10, 2015 12:46 PM
