Prestart or on the fly Octane Optimization for Engine computer?
Car: 1991 Pontiac Trans Am
Engine: LB9 305 V8
Transmission: THM 700R4
Axle/Gears: 2.73 Limited Slip
Manually moved from DIY PROM:
Ok I have searched with no results (can anyone point to where the answer is if answered) but the Question is:
Can the ECM Computer be preselected to run a certain ROM (user inputted) based on Octane of gas in the tank or can a custom computer be built to do this function or even on the fly (while running) although the last scenario is highly unlikely?
The reason I ask is because based on the current escalating fuel pricing I was hoping to have optimized programs for running either Premium, Ultra(Sunoco) or Regular.
The car from the factory recommended running premium but I know for a fact it has in past run on regular gas
Car: 1987 IROC-Z
Engine: 383ci SBC
Re: Prestart or on the fly Octane Optimization for Engine computer?
You can switch between binaries on the fly with tunerprort using hardware such as autoprom or Ostrich 2.0.
Personally I use Ostrich 2.0, you just upload a new binary and it automatically takes effect.
If you were REALLY good, you'd make a digital input to your car computer, so you can just press one of 3 buttons on your dash, and it automatically uploads the correct file to whatever emulator you are currently using... Thats what I'm working on doing, but more for mileage vs performance than differing fuel types.
Car: check
Engine: check
Transmission: check
RBob.
