Ordered megasquirt 2, any other users here?
Old May 9, 2008 | 10:23 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
Who else here has played with MS 2? I have a few questions I cant seem to get answered on the other forums..
Old May 12, 2008 | 09:47 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Ordered megasquirt 2, any other users here?
hello there.
Ms-II v. 3.0
Old May 17, 2008 | 01:52 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
did you assemble your own? I have a question about the db37 ( I think ) connector, the main one that plugs into your engine harness. on the harness side, do you solder the wires into the plugs or is there a trick to sticking wires in it?
Old May 17, 2008 | 05:05 PM
Toehead's Avatar
I did assemble my own. I actually bought the 12 inch db-37 harness from DIY. If you use the one that comes with the megasquirt, solder the wires. Make sure that you use all the ground wires and then twist them together after the pins to make one good ground wire.
Old May 17, 2008 | 09:30 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thank you, could you elaborate on the fuel injector wiring, I know there are only 4 wires for the 8 injectors, do 2 injectors go into each Pin hole?
Old May 18, 2008 | 12:33 AM
Toehead's Avatar
There are two "banks."
Each bank takes two wires (the wires and pins are too small individually to handle the injector current, so two are used and joined together)
Here is the external wiring diagram.
You can wire up the injectors as passenger/driver side banks (like me) or by firing order.
It doesnt really make a difference.
So, if you choose to wire it the way I did, all the passenger side injectors are one bank, and all the drivers side injectors are the other bank
Old May 18, 2008 | 01:07 AM
1320jon's Avatar
Car: 87 iroc
Engine: 402 twin turbo lsx
Transmission: th400
Axle/Gears: 9" 40 spline MW, with 3.25 gears
I almost have my ms2 v 3.0 running. Im guessing you guys are using another option for ignition? I had my dad (electrical engineer 35 yrs) make the hardware changes on a DIY assembled unit.
Mine is in a 66 vette, and I bought the other connectors from efi connection.
So hopefully, as soon as I can get the headers done (Im building them) it should be runnning, hopefully around the end of teh month.
Old May 18, 2008 | 08:17 AM
Toehead's Avatar
I'm using the megasquirt to control ignition as well.
Old May 18, 2008 | 12:16 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Thats what I plan to do, I think its pretty straight forward wiring from the HEI however right?
Old May 18, 2008 | 01:57 PM
Toehead's Avatar
Yes, it is not too bad at all.
If you use the 8 pin module be aware that there is an incorrect resistor value that will really screw you up.
If you are, let me know and I will elaborate further.
Old May 18, 2008 | 02:07 PM
pizza_guy's Avatar
Car: 84 Z28 H.O. w/Megasquirt II
Engine: semi-stock L69
Transmission: T-5 non W/C
Axle/Gears: 3.73 open
MS 2, V3.0 as well.
Still running with the stock ignition, but I keep losing modules. Mine only last anywhere from 2 weeks to 6 months for some reason.
I'm curious about the resistor error though. Just to see if it could affect my 7-pin HEI setup.
Old May 18, 2008 | 02:22 PM
Toehead's Avatar
It could possibly... What ignition capture are you using ?
This only applies if you are using the hall circuit. The vr circuit should be fine.
Does the module test "bad" on a machine?
Old May 18, 2008 | 05:26 PM
1320jon's Avatar
Car: 87 iroc
Transmission: th400
I thought I was on ls1 tech when I asked about the ignition....I have an ls1 in my vette, so I thought (at the time) that we were talking lsx engines. Sorry.
I hope to have ms2extra running my ls1 shortly anyhow.
Old Jun 1, 2008 | 10:27 AM
pizza_guy's Avatar
I am using the hall circuit.
Yeah, they test bad on the machine. These modules are getting cooked somehow, and I've yet to figure it out. My max dwell is very appropriate for my setup.
I'm beginning to think it's a design problem with the ignition. Every HEI ignition I've ever owned has burned through modules. Even though I have been cleaning off the old "heat-sink" grease and applying new stuff every time.
Old Jun 1, 2008 | 10:41 AM
Toehead's Avatar
It very well could be.
Ifyou keep burning through the modules, I would use the module to fire an external coil driver. That would keep the module from heating up.
As for the resistor value, it mostly deals with "losing" signal on hot days, which was very very frustrating until i figured it out.
Old Sep 14, 2008 | 11:09 PM
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
I finally got everything I need this weekend. I also got the computer assenbled and ready to go, hopefully. I now have it communicating with the computer also, so the stinulator is working well. How is everyone else going to run the system. I am completeing getting read of the TPI wiring and just using the megasquirt and relay board. So now I have wiring fun to deal with. How is everyone else using their megasquirt system. By the way I am using an 8pin so any info on that would be great. THanks
Old Sep 19, 2008 | 01:09 PM
Toehead's Avatar
I made a harness out of an old TPI harness.
1MeanZ
Dec 18, 2015 05:39 AM
New2Chevy
Sep 28, 2015 12:35 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
