lean cruise maps
Old May 31, 2008 | 01:36 AM
hjcoupe's Avatar
lean cruise maps
Hi all,
Just a question on lean cruise maps in tunerpro rt on my aussie 5.0lt V8.
I am running the 16183082 ECU similar to the US (165)
In my FVE1:Volumetric Efficiency as a function of MAP and RPM (low RPM)
at my cruising speeds of 80KPH (50mph) my map shows at 1600rpm-50kpa the cell reads 53.52.
Now in my F61:Lean Cruise Air Fuel Delta Vs RPM and MAP in the same 1600rpm-50kpa the cell shows 2.00.
Does that mean the 2.00 cell is subtracted from my main cell of 53.52 to become 51.52 hence leaning out the VE.
The reason i ask is that i'm running about 16.5 - 17.0 AFR when in lean cruise and get a slight "hunting" at the speed/maps i mentioned.
So if i lowered the lean cruise map cell to say 1.50 that would mean my main VE map would now be 52.02 and slightly "richer" than before?
Am i on the right path or completely wrong and should go to the back of the EFI class
Cheer and thanks for any info....Mario
F-body-fan
Jan 12, 2023 01:49 PM
Mark_ZZ3
May 24, 2018 01:02 PM
aaron7
Sep 30, 2015 09:15 AM
tattmann
Sep 27, 2015 05:20 PM
