LT1, with Megasquirt and EDIS/Distributorless ignition -toothed wheel question
Car: 89 GTA
Engine: 350 LT1
I already have my LT1 in my '89 TA. works great with tunercat.
I want a little more control and visibility as to what the motor is doing. Megasquirt was the cheapest and in my case the best choice.
Trying to figure out if there is a 36-1 toothed wheel that someone has found to fit the crank pulley without too much modification. I want to run EDIS (already have the parts) so that i can go distributorless. I'm figuring on using LS1 coils.
Can anyone point me in teh right direction? I found a great article on it from a guy who put an LT1 into an S10, but the article fell short of the actual wheel used.
Thanks.
Thanks.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: LT1, with Megasquirt and EDIS/Distributorless ignition -toothed wheel question
You should be able to use a ford ring. This one on ebay has measurements provided. If you can weld it to the back of the crank pulley or balancer, it should be fairly easy to make a bracket for the pickup, using one of the accessory bolts.
http://cgi.ebay.com/ebaymotors/EDIS-...m110261073302&
1992 Trans Am
Aug 8, 2015 08:16 PM
1991, 350, 361, 50, chevrolet, chevy, distribuitorless, distributorless, edis, ignition, kit, lt, lt1, megasquirt, megasquirtedis, tpi, truck
