Is the ECM messin up my speedo?
Old Jun 6, 2008 | 09:39 PM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
My speedo only works when you get on the gas. Its a 92 RS so it's electronic.
Old Jun 7, 2008 | 08:45 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Is the ECM messin up my speedo?
The ECMs in the TBI cars don't have anyhting to do with the VSS. There is a separate 4-out buffer box that converts the mag VSS signal to pulses streams. These streams each go to the speedo, ECM, and cruise.
RBob.
Old Jun 9, 2008 | 04:08 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I would try replacing the VSS first, that would be more likely to go bad than the buffer box or speedo.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
