305 computer on a 350
Old Jun 11, 2008 | 08:25 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
I bought a 91 RS that I thought had the original L03. Turns out it has a 350 in it. I think it is the L05. it was put in pretty half-a**. I think it still has the 305 computer on it. i'm sure something needs to be done about this for it to run at its potential, so do I need to swap the ECM (ECM and computer are the same thing, right?) or will getting a chip burned take care of it? I don't know enough about these to understand if the actual computer makes a difference or just the tune contained in the chip.
I'll have to learn to tune later but thats at least a year off so I need to do something to get a good baseline for the engine to run off. Ideas?
Old Jun 11, 2008 | 08:31 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: 305 computer on a 350
Check the TBI section they have a while sticky on a 305 to 350 swap, the 305 computer can be used on a 350 there the same in thirdgens, only the chip is different, dont quote me on that though. The only thing that needs to be changed is the chip. You need to either get someone to burn you one or DIY. I have a 350 run by a 305 computer and chip and it runs fine, it just runs lean.
Old Jun 14, 2008 | 01:57 AM
Regal105's Avatar
Car: 83 c10, 2015 silverado
Engine: 454, 5.3
Transmission: Turbo 35o, 6l80
Axle/Gears: 3.42, 3:23
i have a lo3, 700r4 and i have access to an ambulance computer from a early 90's gm van, does anybody think or know if it will have any more potential "power" that a stock one?
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
