using tunerpro rt
Old Jun 17, 2008 | 09:28 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
using tunerpro rt
when using tunerpro rt what are you supposed to do to get everything working between the computer the moates cable and my 1986 305 tpi????
is there a link someone can give me that will have a step by step instruction manual????
i just need to know what needs to be loaded into the program to get tunerpro rt to talk with my 165 ecm
i just want to datalog so i can do diagnostics i do not wish to use it to tune with the chip
i have downloaded ads files txt files ecu files etc... just not sure what the heck to do with them. tried uploading one or the other into tunerpro rt nad didnt make any difference couldnt get any readings but it believe its making contact with teh cable
i think i got working once but said it does not understand the pcm data
i did download a 165 mask file but the info on it is for someones personal 1989 tpi but i need 1986
Old Jun 18, 2008 | 12:13 AM
Bobby_80s's Avatar
Axle/Gears: no idea
Re: using tunerpro rt
i opened an account on the tunerpro forum hopefully ill get a response and ill call moates.net support team tomorrow
hopefully i can get some progress
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
