A few questions on the megasquirt
Old Jul 2, 2008 | 06:47 PM
91Z28's Avatar
Car: 91' Z28
Engine: 355-Supercharged
So im thinking of buying one, but i have a few questions (damn there is alot of reading involved)
So the Ms II has spark control, or so i read, can i use this feature with msd6 btm and a stock distributer/coil setup ?
The MS wiring harness has me slightly confused, so it plugs into the unit and i have to add the appropriate GM plugs for the sensors? or do i splice near the factory ecu? or am i cutting those wires to the ecu and splicing with the wires that go to the MS ?
The Stimulator i understand helps you check your wiring job, and helps you get to know the MS, it connects directly to the MS or do i need a cable ?
Thx guys, back to reading
Old Jul 3, 2008 | 02:11 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: A few questions on the megasquirt
The stim plugs directly in, no cable needed.
The MS-II does control timing without hardware mods. Here are the instructions for the MSD box.
http://www.megamanual.com/ms2/msd6a.htm
As for the wiring, you can do it either way. If you want to replace the ECM, get a short megasquirt harness and cut and splice it into the appropriate connectors under the passanger side dash.
If you want to redo the harness for the sake of having a neat engine bay, go ahead.
It's all up to you.
Old Jul 3, 2008 | 06:50 PM
91Z28's Avatar
Car: 91' Z28
Id like to run both, or mostly just leave the factory ECU to do whatever it does minus running the engine, so in theory i could go to a junk yard get all the connectors and wire them up to the MS cable and plug them into the factory sensors?
Will this cause a problem with the factory ECU not being able to read those sensors, seeing as they will be unplugged ?
Thanks a bunch
Old Jul 8, 2008 | 08:39 AM
Toehead's Avatar
"Whatever it does minus running the engine"
What exactly would this be?
There is a megamanual page on sharing sensors, special care needs to taken on some sensors (clt, iat, etc) that rely on resistance.
Old Jul 8, 2008 | 06:03 PM
91Z28's Avatar
Car: 91' Z28
I was under the impression it also controlled the speedo in 91-92 cars...
Old Jul 8, 2008 | 07:25 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Along with the cruise & knock detection filter. . .
RBob.
Old Jul 9, 2008 | 07:38 AM
Toehead's Avatar
The buffer is internal to the 91's?
I thought it was the yellow box on the back of the ECM.
Old Jul 9, 2008 | 11:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the '7730 ECM the VSS buffer and knock filter are internal.
RBob.
Old Jul 9, 2008 | 12:23 PM
Toehead's Avatar
That is interesting. I've never owned a '7730 ECM. That is good to know.
Would it be possible for him to use a buffer from an earlier car?
The megasquirt is set up to use the 16022621 ESC module from the older cars, so he could use that to condition the knock signal.
Old Jul 9, 2008 | 05:22 PM
jayk2k3's Avatar
Car: 85 camaro z28
Transmission: auto to manaul
consider the holley 950!
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Thirim
Aug 13, 2015 03:09 PM
