fuel pump pulsator?
Old Jul 12, 2008 | 08:53 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
fuel pump pulsator?
Does the fuel pump pulsator look like the top of an old school master cyclinder, metal and two humps on the top? I have a part the is press fit inbetween the pump and hard line in the tank and one sid of it looks like I discribed above. The reason I ask is I am having fuel pressure issues with my current walbro pump and think that I am going to replace that piece with a EFI ruber line with two hose clamps.
Old Jul 13, 2008 | 09:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: fuel pump pulsator?
Yes, sometimes referred to as the turtle.
RBob.
Old Jul 28, 2008 | 10:51 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
what does it do? im replacing my pump and seen it and wondered what is was for.
Old Jul 29, 2008 | 02:04 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
http://www.autozone.com/az/cds/en_us...rInfoPages.htm
Old Jul 29, 2008 | 07:07 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
do i even need this thing? upon mounting my new pump it didnt want to fit right. seemed like it would leak.
Old Jul 29, 2008 | 11:01 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Common for them to leak. It is better with the pulsator in place. However, due to leak issues it is common to replace them with a piece of hose and clamps. Hose needs to be submerge-able type. I have the spec here, hang on. . . Here it is: SAE J30R10
And use good hose clamps. No fun having the hose split or slip off.
RBob.
Old Jul 29, 2008 | 11:50 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
the pump i got came w/ a hose and clamps in case my car was the w/o pulsator type.
why is it better w/ it in place. it really doesnt do anything but quite the pump alittle. b4 my pump went i could not even here it come on to prime the fuel system.
has anyone removed them and had success? if i need it ill keep it, but the way it fits w/ the new pump makes me unconfortable for it to fall off or leak b/c of a bad seal.
Old Jul 31, 2008 | 06:53 AM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
need to know if i should keep it or toss it? tank going back in this weekend.
Old Jul 31, 2008 | 09:14 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I replaced it with the rubber hose that came with the walbro pump...... No problems thus far.
Old Jul 31, 2008 | 09:27 AM
RyanA's Avatar
Every Walbro pump I've put in my cars, I have removed the pulsator. Fuel pump sounds a little louder; that was the only drawback I have seen to speak of.
Ryan
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
