help???ecm and dash wiring
Old Jul 15, 2008 | 09:47 PM
89ftbi2tpi's Avatar
I HAVE AN 89 FIREBIRD.
CURRENTY. IA M BUILDING A 383 STROKER FOR IT.
THE CAR WAS TBI 305-SWAPPING TO TPI FROM A 92 CAMARO(NO DONOR VEH) WITH A 91-92 HARNESS NOT FROM SAME TPI SETUP.
IVE BEEN TOLD I CAN SWAP PIN LOCATIONS IN THE DASH WIRING AND FUSE BLOCK JUNCTIONS?/ IS THIS POSSIBLE
THANKS
ANY HELP
Old Jul 16, 2008 | 02:25 PM
Pocket's Avatar
Car: 91 Trans Am
Re: help???ecm and dash wiring
Turn your caps lock off
http://www.austinthirdgen.org/index.php?pid=19
Scroll down to the bottom under connector pinouts
Compare, label, repin, run
Old Jul 17, 2008 | 01:45 PM
89ftbi2tpi's Avatar
thank you,
this will help me a lot
stalkier
Dec 6, 2015 11:25 PM
stalkier
Aug 21, 2015 01:54 AM
355tpipickup
Aug 19, 2015 10:02 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
