tps problem w/ dfi
Old Aug 11, 2008 | 12:44 PM
rokn91rs's Avatar
tps problem w/ dfi
i have installed a gen 7 on my lt1. the computer is not reading the tps sensor. i have checked the placement of the wires and they are right. trying to set the min and max tps volts they read the same. i have a code 23 for low tps volts. any ideas that might help are welcome. thanks
Old Aug 13, 2008 | 11:36 AM
jonarotz's Avatar
Car: 91 Z28
Re: tps problem w/ dfi
What harness are you using? I would triple check the wiring. Check them all the way back to the ecm. There really isn't much it could be. are you positive the sensor is good? Do you have 5v Ref to the appropriate pin at the sensor?
Old Aug 25, 2008 | 09:07 AM
88Iroc88's Avatar
tps should have 3 wires going into it, 12 volt power wire, ground, and 5vt ref wire, take a volt meter and test for voltage and ground if you have both then check for 5vtref signal, with the tps plugged it take volt meter and aand touch to bare wire on 5volt ref , slowly open the throttle with vech off and key on, at wideopen volts should be close to 5volts ,closed to be a 1 volt or below, if everything checks out good at sensor then trace wires to make sure there not burnt or broke, if good then bad ecu, if no power at the tps, check wire if that good then bad ecu, if no ref signal then bad tps
Old Sep 17, 2022 | 04:34 PM
monkey-leader's Avatar
Engine: 6.0L LY6 (Vortech Supercharged)
Transmission: Tick Performance T-56
You ever get anywhere with this?
Old Sep 17, 2022 | 04:47 PM
In case this comes up again, I'll tell you how I fixed this.
​​​​​Of course I figured this out after tracing and testing the harness, as well as verifying the ECU board was not blown.
TLDR; Disable the High TPS and Low TPS Error codes. Then erase all codes. You should now be able to set the values to the correct setting. There is probably some kind of protection setting that disables the readings if they are out of what is expected.
Gizmoz28
Sep 26, 2020 10:18 PM
Youngs92
Sep 20, 2013 05:23 PM
Cornflakekid
Mar 23, 2012 09:55 PM
Rick King
Nov 4, 2009 03:23 PM
thirdgen4me
Feb 20, 2009 07:36 PM
