88 camaro tpi 305 sensor and ground
Subscribe
Sep 23, 2020 | 07:36 PM
i found 2 grounds that are spliced together they go to the tps and the cts sensors should these have seprate grounds i cant get a good reading on the multi meter should i split the wire and connect them seprate thanks
Reply 0
Sep 23, 2020 | 07:46 PM
Re: 88 camaro tpi 305 sensor and ground
May,cts &tps splice together and go to d2 of the ecm
Reply 1
Sep 23, 2020 | 07:55 PM
ok thank you
ive been trying to get a volt reading on the tps and the meter is going crazy cant get it to stay at .54 volts for the tps
Reply 0
Sep 23, 2020 | 08:56 PM
Disconnect the tps and turn the key on. Check the grey wire. Should be a solid 4.5-5v.
if it’s fluctuates sounds like a bad ecm. If it’s solid and voltage fluctuates on the blue wire while plugged in to the tps the tps would be bad.
Reply 1
Sep 23, 2020 | 10:41 PM
Thanks tuned I will test it again and get back to you
Reply 0
Sep 26, 2020 | 10:10 PM
Hey tuned checked out the tps the wiring was bad fixed it car runs a little rough still now I want to check the maf how would I test this thanks
Reply 0
Sep 26, 2020 | 10:18 PM
Best way is to see gps in a datalog but search Vader’s latest posts for checking with a vom
Reply 0
Subscribe
