TPS ground connection?
Old Jul 19, 2005 | 08:19 PM
firebirdjosh's Avatar
Car: 86 T/A
Engine: HSR 355
Axle/Gears: 2.77 posi
The black wire of the TPS sensor goes to "sensor ground" on the ECM. Using a resistance meter I get a reading that it connects straight to ground. Does that I mean- theoretically- that I could cut that wire, tie it straight to the negative terminal of the battery and not notice a difference in performance? I don't plan on doing it, I'm just wondering if the ECM "sensor ground" connections really goes to ground for testing purposes.
Old Jul 19, 2005 | 09:07 PM
Big AL91's Avatar
Car: '91 Camaro
Engine: 305ciV8LO3TBI
Transmission: Auto.
You are right in theory, but don't do it. The ECM will trigger the circuit ground(batt neg) in consulation with its other computor circuits including memory, to keep your engine healthy. Good Luck!
Old Jul 19, 2005 | 09:12 PM
Car: 86 T/A
Engine: HSR 355
Alright thanks alot.
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
Slush92RS
Sep 2, 2015 08:56 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
