need help with throttle position sensor
Old Aug 24, 2009 | 05:15 PM
littletimmy9's Avatar
need to know where the wires go from the throttle position sensor to the brain box on a 86 camaro with 305 tpi engine wires are fraied not getting power to sensor can can any one help
Old Aug 27, 2009 | 03:48 PM
Pocket's Avatar
Car: 91 Trans Am
Re: need help with throttle position sensor
TPS is pretty simple. It has a common 5V (gry) wire which splices into pretty much all other sensors requiring 5V
A GRD (blk) which also splices into the common ground for every sensor and eventually is bolted to the rear of the cyl heads
The Signal wire(blu) is connected to the ECM
If you have no voltage across the gry wire with the IGN on then you have a break in the wire somewhere. Check voltage on any other gry common to test if you're getting 5V from the ECM in the first place. If you have 5V there, simply splice off of it to the break in the TPS wire
Old Aug 28, 2009 | 10:34 PM
ok thanks sounds not to hard will try
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
