1227747 ecm
Old Aug 12, 2008 | 04:11 PM
motohead's Avatar
1227747 ecm
I have a 1991 c1500 truck with the 1227747 ecm and I was wanting to know if there was any way that this computer could run an electric fan. If not could I swap the computer for something that would and would not be a PITA to re-pin?
Old Aug 13, 2008 | 07:18 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 1227747 ecm
The EBL Flash is an easy way to go. Has electric fan control along with other nifty features. You can get either the self-install and put it into your ECM, send your ECM to have it installed, or get the EBL FLash with an ECM. As the EBL Flash can be used with a '7747 there is only a couple of pins that may need to be changed (added features).
RBob.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
