as soon ad closed loop engages. i loose my connection with the scanner.
Old Oct 7, 2008 | 10:58 PM
BigBoi4Lyph's Avatar
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
so when i hook up and otc scanner to my 87 iroc 5.7 tpi i have data and can read codes in open loop as soon and it goes to closed loop i mean right as it changes i lose all data and cant even read codes on the scanner.
im thinking literly the only thing that can cause this is the ecm itself?
and input will help.
Old Dec 2, 2008 | 03:22 PM
Car: 89 Iroc
Engine: 5.7 TPI
Re: as soon ad closed loop engages. i loose my connection with the scanner.
hey i could really use any and all input on this situation. ive yet to ben able to aquire a pcm or prom to swap and try it out. but it still will not read data once the pcm switches to closed loop.
but when the car is cold it will read codes/ data untill closed loop arrives.
literly the only thing that could posibly cause this is the pcs itself correct?
F-body driver
Mar 6, 2023 11:44 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tglennon11
Sep 23, 2015 05:30 PM
TheTraut88
Sep 7, 2015 05:22 PM
luvofjah
Sep 3, 2015 07:08 PM
