Can you simply swap a 305 ecm with 350 ecm?
Old Nov 12, 2008 | 01:45 AM
fearthisinc's Avatar
Just wondering if you could swap a 350 computer into a vehicle that had a 305.. my car came stock with a 305 however previous owner put in a 350.. not sure what is in there right now but if it is the stock 305 computer then am I correct to believe that by putting in a computer that was in a 350 that would produce better/more power results? and then from there i could chip the 350 computer? or can you not just swap the computers that easily?
Old Nov 12, 2008 | 04:12 PM
Iroczracer's Avatar
Car: 1989 IROC Camaro
Engine: Stealth Ram 355
Transmission: WC T-5
Axle/Gears: Torsion 3.42 Posi
Re: Can you simply swap a 305 ecm with 350 ecm?
I think the basic ecm is the same if it started as a 5.0 TB car. If it went from tb to tpi there would be some differences. Or from MAF to speed density, you should be able to tune your ecm. You can buy equipment from Moates or others, I used the Moates products...
Old Nov 12, 2008 | 04:17 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
On the TPI models, I know that the ecm is same with a different memcal inside.
I assume the TBI is same, don't really know about TBI.
Old Nov 13, 2008 | 01:19 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The computers are identical, its the chip inside that is different.
Old Nov 13, 2008 | 03:34 AM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Long shot, but if your old ecm is a 1227165 from a 1989 305 TPI auto, I may be interested in buying the MemCal from you or the whole ECM, if your willing to let it go cheap enough...
Frozer!!!
Jan 19, 2024 04:55 PM
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
