need help on tpi ecm swap
Old Nov 18, 2008 | 09:45 PM
johnny090881's Avatar
Car: IROC
Engine: 383
Transmission: T-5 manual transmission
Axle/Gears: 3.45
I have a 88 camaro tbi manual transmission and want to swap it out with a tpi setup that came w/the ecm but it's off a automatic. would I have to replace the chip, find the tpi manual trans. ecm or can I simply just replace the chip by buying a hypertech chip for a tpi manual trans?
Old Nov 19, 2008 | 07:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: need help on tpi ecm swap
You can use the auto chip in a stick vehicle. It isn't ideal but usually works out OK. It is the other way, a stick chip in an auto that is bad news (TCC lockup is all wrong).
RBob.
Old Nov 19, 2008 | 08:19 AM
Car: IROC
Engine: 383
Axle/Gears: 3.45
cool, what about swaping the chip out and puting a hypertech tech stage 1 chip for a tpi manual trans. will that work and how about the wiring harness that goes to the transmission
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
BOOT77
Aug 10, 2015 12:20 PM
marcusaw
Aug 10, 2015 08:13 AM
