Injector Constant Question
Car: 84 Z28
Engine: Stealth Ram 355
Transmission: Borg/Warner T5 WC
I have means of adjusting my fuel pressure on my TPI and I wan't to put the correct injector constant in my bin. Should I calculate my flow rate for the fuel pressure I have with vacuum or without? It may seem like a newb question, but I haven't been able to find the right search terms to find the answer to my question, and I've never had stock equipment to do any tests with.
Car: check
Engine: check
Transmission: check
Re: Injector Constant Question
You should set the fuel pressure and use that value for the injector flow rate with the vacuum line off. I usually just leave the engine off and hot-wire the pump. Many year harnesses had a pig-tail with a fast-on to allow easy hot-wiring of the pump.
Note that increased fuel pressure decreases the available flow from the pump.
RBob.
RBob.
Car: 84 Z28
RBob, I think you're gonna single handed teach me about tuning a car one question at a time. You have all the answers. Happy New Year!
