ECM CHIPS
Old Jan 5, 2009 | 02:05 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
ECM CHIPS
i have an 85 IROC that i am having some drivability issues with.
after checking all the sensors and verifying that they are working and in range, i believe my trouble is with the ECM, more specifically, the chip thats in it.
the engine i have is a 350 with the tpi from the original 305.
i believe it has larger injectors to go with the larger displacement, but i cannot be sure. i didnt build the engine and have no details of what lays inside.
anyway, i have been looking for a custom chip and have hit a road block.
350s werent put into camaros until 87, but in 86 they switched to a new computer.
obviously i cant use a 305 chip because that would give me even more problems.
can i use an 87 chip in a 85 computer and be fine or do i have to either have a custom chip burned or switch ecm's
thanks
Old Jan 9, 2009 | 07:55 AM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: ECM CHIPS
thanks
There's a thread on here somewhere that tutors you on the change.
Old Jan 9, 2009 | 08:45 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: ECM CHIPS
any idea how to find it?
i searched
Old Jan 9, 2009 | 06:09 PM
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Re: ECM CHIPS
thanks
My dad has an '85 Z28 with the same situation. 305 stuff running a 350. I think it has the 305 injectors as well. Anyway, the difference is that his runs fine. (It actually runs better than my '89 that is running a 305 with 350 stuff, ) Anyway, I think you can get a chip out of an '85 Corvette. It would be a 350 chip and the '85 Vette used the same computer as the Camaro for that year. ...But, if you are getting a custom chip, what difference does it make? Then again, in my own searching for custom '85 chips, I have found that no one seems to do them (for cheap anyway), it is always '86&up... Hence, my consideration of the '85 Vette chip...
TPIS does '85s, but they want a decent chunk of change...
HyperTech (which can be obtained from TPIparts) also offers chips for '85s, but they are fairly expensive too...
To answer your other questions. The chips have to correspond to the computer they are installed in. Not so much the chip, but the programming on it. However, the chips in '85 were actually physically different than the ones from later years. So, no you cannot use an '87 chip in an '85 computer. Also switching ECM's is not really straight forward either, as the '85 has a different pinout for the harness connectors than the later years...
Old Jan 10, 2009 | 04:42 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: ECM CHIPS
hows this look
http://store.summitracing.com/partde...5&autoview=sku
i figure a 49 state chip will be more "powerful" than a 50 state chip, and since i dont have a stock motor, this might be a better route.
btw, i have no clue what is in the motor.
Old Jan 10, 2009 | 06:02 PM
BlueIroc-Z's Avatar
Re: ECM CHIPS
I dunno, you could have problems if your injectors are not equivalent to what was stock on an '85 Corvette...
Old Jan 10, 2009 | 06:08 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: ECM CHIPS
good point.
anyone know what injectors are on an 85 corvette?
also, how do i know what injectors i have?
is it like stamped on them or something?
Old Jan 10, 2009 | 06:47 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: ECM CHIPS
well according to summit, the stock injectors for a 85 corvette is 24lb injectors.
still dont know how to figure out what i have though
Old Jan 11, 2009 | 09:51 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: ECM CHIPS
anyone?
bueler?
Old Jan 11, 2009 | 11:17 PM
BlueIroc-Z's Avatar
Re: ECM CHIPS
Sorry for the delayed response, didn't get a notification 'till just a while ago. Anyway, the injectors will have a number on them somewhere. It will be pretty small, you'll have to get pretty close to read it. If you can get that number, post it up and I will see if I can help you find out what injectors you have.
Old Jan 12, 2009 | 11:09 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: ECM CHIPS
ok.
are the numbers on top or do i have to remove the injector?
i guess i can just look lol
im lazy
Old Jan 12, 2009 | 04:25 PM
BlueIroc-Z's Avatar
Re: ECM CHIPS
Here's a picture (from fiveomotorsport.com):
Probably Ford injectors given the source, but they look very similar to the ones on my Camaro, so anyway the part number is there on that little flat area just above the silver colored part. Your injectors probably aren't silver like that, but it gives a general idea of where to look. You shouldn't have to remove the injector to see this number.
Old Jan 25, 2009 | 12:06 AM
defaced's Avatar
Car: 1987 Firebird Formula
Engine: 355
Axle/Gears: Posi, 3.23
Re: ECM CHIPS
Sorry wrong thread.
Old Jan 25, 2009 | 09:54 AM
scuzz's Avatar
Engine: LB9
Axle/Gears: 3.55
Re: ECM CHIPS
All the L98 TPI 5.7 injectors were 22#, and the LT1 was 24# from what I've always seen.
I've used 19# Ford SVO (Bosch) injectors in my 5.0 TPI 40 Chevy for about 8 years now with no problem at all. No changes to ecm and it runs great and I got 26.2 mpg last 1300 mile round trip to Daytona on the road part and 17 mpg in town part.
The 85 5.0 TPI I started with had Multitec injectors, but not sure about 5.7.
This link might help.
http://www.chevythunder.com/
There's a list of part number, mfg, and rating in the intake section.
Old Jan 31, 2009 | 05:07 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Re: ECM CHIPS
-85 Vette uses 24lbs injectors and 39 psi fuel pressure.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
2012sergen11
Oct 13, 2015 07:38 PM
ramicio
Sep 28, 2015 01:18 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
Ranbo108
Sep 9, 2015 12:20 PM
