CC-Carb & ECM need help
Old Jan 27, 2009 | 12:36 PM
MikeSmith0890's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 2.8L, hopefully upgrading..
Transmission: BorgWarner T5, Made here in Muncie
Axle/Gears: stock
I can't seem to get my motor to idle right and run correctly.. It'll drive just but seems to idle high and use more gas than it should. I was wanting to try and tune it and see what happens.
My question is.. its a 2.8L motor with a CC rochester Varajet E2SE. Not sure what the ecm is.. the car is an '83 SC with a 5spd
Will WinALDL work to do this.. I know i'll need the USB aldl cable.. is this all i need or what else?
Again im new to this so alot of help would be greatly appreciated. I tried searching but couldnt find anything for my setup..
Thanks again,
Mike
Old Feb 2, 2009 | 12:13 AM
Axle/Gears: stock
Re: CC-Carb & ECM need help
bump
Old Feb 3, 2009 | 09:43 AM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Us CC-guys seems to be a minority here, presumably regarded as freaks or retards..
Please excuse my rants, I'm just trying to make a joke - on my own expense..
But the fact is that info on CC systems is much harder to get hold of than on FI.
Now, I don't have any info at hand on this but I can try to help you out. If you can try to locate the ECM and read the 122- or 165- number on it, and perhaps also the BCC-code on the PROM beneath the small lid on the ECM, then we can try to go from there and see if there's anything to be found about it.
WinALDL can always datalog anything OBD1. It can also show sensor values and error codes - if that engine is included in its programming.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
