code 43 and 33, hot relay, bad esc?
Old Feb 3, 2009 | 03:25 PM
noboostnogo's Avatar
Car: 1989 Turbo Trans Am gta
Engine: 383 78mm turbo
Transmission: Th350 rmvb with brake
Axle/Gears: 9 bolt 3.45s
so ive been having some issues with my engine lately, It bogs down when i first give it some gas then picks up, a few missfires everynow and then.
I have replaced IACV, coil, dizzy module, dizzy cap, spark plugs, plug wires, 3 wire o2 sensor.
and i adjusted my tps.
I was trying to find the problem the other day and felt that one of the relays was warm, i unplugged it and the car ran 10x better but i got a SES. i went and bought a new relay and got better but still does it. when i unplugged it that time i hooked my laptop up to it and got codes 43 ESC failure and 33 MAF high. could the sensors be bad?
my car is a 89 trans am, came stock with a 305, i put a 350 in it and got a chip from tpichips.
I never replaced the 5.0 esc for the 5.7 esc. or knock sensor.
Swap was done about a year and a hlaf ago.
as stated above when i unplug the relay it runs like it should with a fast throttle response and starts right up.
ive narrowed my problem down to either : Bad MAF, BAD ESC, BAD KNOCK SENSOR or a short somewhere along the wires.
What could it be? thanks in advance
Old Feb 5, 2009 | 07:29 AM
Re: code 43 and 33, hot relay, bad esc?
anyone??
Glowsock
Jul 24, 2025 03:15 PM
89GTAOz
May 16, 2020 09:31 AM
db057
Sep 4, 2015 07:57 AM
Bert87
Aug 23, 2015 03:50 PM
