ECM replacement
Old Feb 12, 2009 | 03:43 PM
jshepit's Avatar
Car: 1988 IROC
Transmission: BW 5-Speed
Axle/Gears: 3:73
ECM replacement
Have an 88 305 TPI and have done quit a bit of troubleshooting and seem to have narrowed down my trouble to be either the ECM or possibly the Eprom. In field service mode (A&B) jumpered it would run ok, but now it won't run at all. My question is if I replace the ECM with an aftermarket ECM (non-AC Delco) does the assemble come with the Eprom included or do you have to purchase seperately? I want to think it's an assembly (kit), but I'm not sure. I know you can replace the Eprom (for example with a modified or HP version) and use the same ECM, but if I purchase a stock OEM replacement ECM does it come with a matching Eprom? Thanks for your help.
Old Feb 19, 2009 | 09:19 AM
jfwireless's Avatar
Re: ECM replacement
If you buy an OEM replacement ECM, you typically just move your EPROM over to the new ECM. The EPROM has the appropriate bin file for your particular engine. I doubt your existing EPROM is bad, but if it is you can just go get one with the same broadcast code from a local salvage yard.
As for other non -OEM ECM's you would have to ask the ECMmanufacturer that question.
Jim
Jim
specialized
Jun 18, 2022 09:26 AM
89GTAOz
May 16, 2020 09:31 AM
bamaboy0323
Sep 3, 2015 06:07 AM
stalkier
Aug 21, 2015 01:54 AM
marcusaw
Aug 10, 2015 08:13 AM
