Marine stuff...Open to a lot of performance
This could be simple and short. I am in the process of modding a stock 4.3 volvo Gi that has std tbi. The good part is the motor has the right vortec heads and a 2" tb bore sitting atop of a 4 bl intake..Those are all stock..what has been modified is the cam and valve train. the cam is a little hot but will work
http://www.compcams.com/Cam_Specs/Ca...?csid=576&sb=0
I really have no ideal if this can be done, but i am intrested in pursing it a little farther. Can i do this..probably not but i would be open to paying for something like this if it is reasonalbe.
Car: check
Engine: check
Transmission: check
Re: Marine stuff...Open to a lot of performance
Are you up for DIY tuning?
First thing you need to do is to find out what ECM is being used. A picture along with the numbers from it will help.
RBob.
RBob.
Picture002-6.jpg?t=1236208426
Picture003-6.jpg?t=1236208566
Picture004-5.jpg?t=1236208609
Sorry about the macro..cannon not doing good for some reason
1. 16237009
2.867009ka00083363
Here is the issue. If that ecm is burned and does not work Volvo get a thousand for a new one. I believe its closed loop ..no sensor in the exhasut.. Can i go to the junk yard and find one that will work and be modded?
I can tell you know i do not know how to program a ecm...but id pay for one that would work..With in reason of course
Damm merc: http://www.michaelstractors.com/foru...p?TOPIC_ID=199
1. 16237009
2.867009ka00083363
Car: check
Engine: check
Transmission: check
That is a MEFI ECM (Marine Electronic Fuel Injection). Won't find one in the junk yard unless it is a boat yard. Not sure which series it is as they are now MEFI 1 through MEFI 4.
You are correct about it not using an O2 sensor. This makes it an open loop system (open as in no feed back).
There are some MEFI tuning programs available but they are pricey. A 'net search on MEFi will bring some up. Arizona Speed & Marine was one of the first to be licensed by GM for tuning. The MEFI controller was also used on the GM provided RamJet crate engines.
Could switch to an underhood ECM such as the 1227727 and the TPI code ($8D). Lots of support and inexpensive tuning equipment is available.
RBob.
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
RBob.
RBob.
http://www.mefiburn.com/
It is a MEFI-3, ive done a bit of looking around...it seems to be a very basic ecm. I wonder if i would need to reprgram it. Maybe just a adjustable fuel regulator. I going to chase this in another thread . Any suggestions would be kewl..
Guys... If that ECU is toast how would a early version megasquirt work out? would not the price be like < $200 ? ebay? I just looked cheapest is $89 ? I thought there was a member on this site doing harness adapters for MS ?
Hawk312
Aug 22, 2017 08:55 PM
Fast355
Dec 2, 2016 06:33 PM
92projectcamaro
Jan 18, 2016 08:00 AM
