need ecm to run?
Old Mar 11, 2009 | 11:04 AM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
need ecm to run?
so i plan to swap my engine for a carbed 350 once it is exempt from emissions. my question would be is the ecm required for anything else to run? i.e. transmission etc.? thanks
Old Mar 11, 2009 | 02:01 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: need ecm to run?
Lockup on the torgue convertor.
Old Mar 13, 2009 | 01:39 PM
Ronny's Avatar
something tells me the aftermarket has a fix for that allowing you remove the ECU. Check B+M site for lockup control.
Old Mar 13, 2009 | 01:47 PM
manolis1969's Avatar
Car: klowny1969 <-youtube 4 3rd gen vids
Engine: subscribe to klowny1969 on youtube!
Transmission: subscribe to my channel on youtube
i did this conversion..you will need a new distributor and you will have to figure out what ur gonna do with the fuel delivery..you can hook up a regulator to the existing setup....lockup, they sell kits for that...gauges also need to be rewired..how much horsepower in the motor? are you changing ur tranny at all??
Old Mar 13, 2009 | 03:37 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
VATS (starter enable relay)
Fuel pump
Speedometer
Old Mar 13, 2009 | 10:23 PM
Toehead's Avatar
What gauges are you talking about? (other then the speedometer)
I dont even have the stock ECM in my car. No rewiring of the gauges required.
You will have to get a vacuum advance distributor.
Old Mar 15, 2009 | 10:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Federal law says a street car is never exempt from having the factory emissions devices on the vehicle.
And there's a tech article and a sticky post in the carb forum that answers your question.
Are you sure its worth it? I can understand wanting to get rid of the TBI, but isnt TPI, LT1, or LS1 better than downgrading to a carb?
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
marcusaw
Aug 10, 2015 08:13 AM
