In-tank Pump replace?
Old Mar 26, 2009 | 05:16 PM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Hey need an advise,
I am thinking of getting a Procharger D1SC, but not sure if I should replace my stock in-tank pump and it still works fine. I have the external Fuel Pump from Aerimotive A1000. So it is worth to replace the pump out of the tank or will I be okay with the External pump?
I might be wrong, what I have heard that the external pump it doing most of the work and the in-tank does not do much. So it would not be worth to have an in-tank pump? Need help understanding this.
Also, I have the 38lb injectors and should I get the FMU?
Let me know thanks.
Old Mar 26, 2009 | 06:08 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: In-tank Pump replace?
Originally Posted by scottwrightF1
Hey need an advise,
Let me know thanks.
I did a similar deal on my 4th gen, external pump and FMU that came with the (Vortech) kit. I put it on the dyno and fueling was very good, no dips or issues even run to redline repeatedly. The in-tank pump just works as a primer pretty much, but the external pump was damn noisy.
Good luck
TA
Old Mar 26, 2009 | 09:45 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
If I were you I would remove the in-tank pump and just use the external, you can run a piece of line down and put the sock on the end of that in the same location as if the pump was still there. That's how I did my external pump setup on my 4th gen.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
