Scanner Reports: IAC Position 160
Old Apr 7, 2009 | 09:27 AM
neagan's Avatar
Car: 1988 IROC 5.7 Money Pit
Engine: (being built; modified TPI ZZ4
Transmission: 2200 stall/ stage 3 700R4
Axle/Gears: freshened 3.27 in 9.bolt/
I'm having great difficulty getting my ALDL port to send info thru a ECM scanner. I did get a quick 'flash' of info last night where the scanner showed: 'IAC POSITION 160'.
I set my new IAC to a voltage, so am unsure what the 160 number represents? Nitro-Nicky
Old Apr 7, 2009 | 06:34 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Scanner Reports: IAC Position 160
The TPS is set to a voltage. The IAC is going to be at whatever steps the ECM commands it to be.
RBob.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
