Accel Gen 7 Harness Adaptor
Old Apr 7, 2009 | 09:13 PM
iroc90dfi's Avatar
Car: 1990 IROC-Z
Engine: 355 TPIS Mini Ram, Vortech R-Trim
Axle/Gears: 3.73 Strange S60
Does anyone know where I can get a Accel Gen 7 Harness adapter to adapt to my 1990 IROC factory harness?
Old Apr 21, 2009 | 11:50 PM
fastsspr's Avatar
Car: 1985 Yellow Iroc Z w/LS interiors
Engine: 305ci 5.0L
Re: Accel Gen 7 Harness Adaptor
http://whiteracing.com/faq.html
Old Apr 24, 2009 | 08:54 AM
jonarotz's Avatar
Car: 91 Z28
I have heard of people having some issues with the adapter harnesses. I ended up making my own for my setup. After doing some research I found that each injector needed to have its own dedicated wires, mainly the grounds. It looked like the adapter harnesses used only 3 wires just like the stock configuration 1) 12v key 2) right side ground 3) left side ground
If you are decent at wiring I would reccomend sitting down and making your own. Just my
Old Apr 28, 2009 | 01:03 AM
fastsspr's Avatar
Engine: 305ci 5.0L
How you make the all the dash gauges work with the DFI with the new harnnes?
Old Apr 28, 2009 | 07:38 AM
jonarotz's Avatar
Car: 91 Z28
If I'm not mistaken most of the guages are not tied to the ECM. the fuel level, volts, oil pressure, and coolant temp are all independent of the ECM the oil pressure may be tied into the fuel pump circuit as a safety feature but I think that is about it. The tach can be connected pretty much like stock. The only problem you may have is with the speedo. I run a 4L60E transmission and it uses its own ecm which had an output I could use for my speedometer.
1992rs/ss
Jan 31, 2025 05:10 PM
tazs2000
Jul 15, 2017 08:44 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
wild1
Aug 27, 2015 09:01 AM
zayne0
Aug 24, 2015 07:22 PM
