At 110 I Hit The Wall! Help, Question About The Governor.
Old Apr 14, 2009 | 08:21 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
HI THERE EVERYONE, FIRST OF ALL MY QUESTION IS. ON MY CAR WHEN I DROP IT TO 1ST THN 2ND THEN 3RD BUT AT 3RD GEAR NOT EVEN RED LINEING YET AT 110MPH, I HIT A BRICK WALL. WELL MY CAR STARTS TO PULL BACK OR SO IS THAT THE CAUSE OF THE GOVERNOR OR SOMETHING? THEN ILL SHIFT INTO 4TH AND STILL I CANT GO FASTER THAN 110MPH WHATS MY PROBLEM HERE? RPM'S DONT DROP OR SO.
Old Apr 14, 2009 | 09:58 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
Re: At 110 I Hit The Wall! Help, Question About The Governor.
Speed limiter is your problem. It's set to 112mph in the chip. Want to learn how you can remove it? Go to DIY PROM Board and learn learn learn!
Old Jul 14, 2009 | 07:44 PM
Mtrhd329's Avatar
I read a while back that if you put a switch on the VSS signal you can keep going past the 110 mark. It is a lt brown wire at the ECM if my memory serves me correct. This was about 4 years ago and I dont have any of my notes with me here in Iraq. Maybe someone knows where this info is at?
Old Jul 14, 2009 | 09:42 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You are correct. Two clicks from the TGO home page is a tech article on how to do that.
RBob.
evilstuie
Jan 9, 2020 08:29 PM
billybob6110
Sep 24, 2016 09:50 AM
beastin91rs
Oct 9, 2015 07:38 AM
ydnar417
Sep 23, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
