MAF relay help
Old Apr 23, 2009 | 06:26 PM
johnrstuch's Avatar
Car: 89 Trans am GTA
Axle/Gears: not sure
MAF relay help
ok so i was not sure which relay was for the MAF burnoff.
so i did a continuity test on the red wire,and on the blue wire.
these 2 wires are the only 2 that go from the relay directly to
the MAF sensor. according to my haynes manual there's supposed
to be an orange wire,constantly hot.
and a blaclk/pink wire that comes on with the key,this wire is not
powering up.
my question is, is this supposed to be hot the whole time the key
is in the run position.
Old Apr 24, 2009 | 07:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: MAF relay help
On the MAF burn-off relay, two pins should be hot all of the time. These are E and D.
They are fed from the battery via a wire with an in-line fuse. This also provides BAT+ to the ECM, fuel pump, and the MAF power relay.
This is pin A on the MAF power relay. And is shown as orange (which is the common color for battery power).
Pin E (red) on the MAF power relay will be hot whenever the fuel pump is running, or during the MAF burn-off time.
RBob.
Old Apr 28, 2009 | 06:18 PM
f1aws's Avatar
Re: MAF relay help
RBob.
So if your MAF burn off is bad, will that stop the fuel pump from turning on with the ignition?
And where is the MAF relay located at?
Mark_ZZ3
May 24, 2018 01:02 PM
thunder57
Nov 7, 2015 02:28 PM
racereese
Oct 3, 2015 03:46 PM
