'7165 ECM Wiring Q
Old May 9, 2009 | 07:09 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
'7165 ECM Wiring Q
Question about the factory wiring for the '165 ECM on my 89 TA. There is a 12V input (orange wire) that goes into the C1 plug I believe... Is that a switched 12v or always hot 12v source?
Reason I ask... I'm installing my C950 right now and I planned to use the orange 12v source for the factory ECM to tie into the switched 12v need that the C950 has.
I hooked the orange 12v from the factory ECM to the C950 red/white wire, and as soon as I hook up the battery it engages the fuel pump and primes the system... not once the ignition is turned, but as soon as the battery is hooked up...
Based on this I'm guess it's not a switched 12v???
Thanks in advance,
Chris
Old May 9, 2009 | 08:07 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: '7165 ECM Wiring Q
Orange is typically battery power. Pink with a black stripe is typically IGN+.
RBob.
Old May 9, 2009 | 08:47 PM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
RBob.
Well that sure would explain that!
Now that you actually put it in words... I knew that! My brain is fried this week...
Thanks!
stalkier
Dec 6, 2015 11:25 PM
Jae992
Aug 27, 2015 09:07 AM
djmarch
Aug 19, 2015 12:07 PM
stalkier
Aug 13, 2015 12:59 PM
marcusaw
Aug 10, 2015 08:13 AM
