ecm iac pin #
Old May 14, 2009 | 08:15 AM
3rdgengmachine's Avatar
Car: 87 iroc z
Engine: 358 tpi
Transmission: 700r4 with transpack
Axle/Gears: 3.42 with powertrax
ecm iac pin #
anyone know what color and pin # the wires are at the ecm for the iac on an 87 tpi motor.I have the 165 ecm but im haveing a high idel problem and im going to check to see if i have a broken wire from the plug to ecm because everything else is good its either wire short or bad ecm unless theres something i dont know to test for.Im not showing any codes.I need a good scan tool that tells me what the ecm is seeing.While on that topic anyone know what kind i need to tell me this.Im looking at the ones at advance and walmart the walmart is $100 and the advance one is $250 or $300 something like that but id like to know if its what i need for my 87 plus id like to know if it will work on all obd2 cars as well.Thanks experts!!!!!!!ohh yea i need thoes pin # and/or wire colors mostly lol.....
Old May 14, 2009 | 09:01 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: ecm iac pin #
IAC "B" low
C3 Lt. Grn/Blk
IAC "B" high C4 Lt. Grn/Wht
IAC "A" high C5 Lt. Blu/Wht
IAC "A" low C6 Lt. Blu/Blk
best regards
Old May 14, 2009 | 06:14 PM
Car: 87 iroc z
Engine: 358 tpi
Re: ecm iac pin #
cant get any better than that thanks alot man
Old Jun 9, 2009 | 02:33 PM
loquito's Avatar
Re: ecm iac pin #
this is good info do you know if its the same for an 89 iroc 5.7 I need to check some connections
Old Jun 12, 2009 | 09:12 AM
Car: 87 iroc z
Engine: 358 tpi
Re: ecm iac pin #
I would say.It should be the same if you have the 165 ecm like mine
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
L98GTA87
Oct 19, 2015 10:43 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
gta892000
Sep 16, 2015 12:37 AM
greenyone
Sep 2, 2015 03:39 PM
