Need Help Identifying ECM
Old May 14, 2009 | 11:21 AM
FireChicken2.8's Avatar
Car: 1989 Red T-Top Firebird, 1989 Iroc
Engine: 2.8L 173 C.I., 355
Transmission: Th700r4 Auto, Built TH700R4
So I'm trying to track down the proper ECM and PROM for my 305-350 swap. And i had determined that the ECM that came with my 89 Iroc 305 TPI would work, and I would just need a prom. But today I pulled it down and this is what I found. Its a reman ECM, and the numbers don't seem to match up with anything on this list. http://www.3rdgenformula.com/89/promcodes.htm
So i was wondering if any of you experts out there could help me determine what ECM this is. Your help is greatly appreciated!
Old May 14, 2009 | 11:29 AM
Re: Need Help Identifying ECM
I believe it is the replacement for a 1227165 which is what was originally in there, but can anyone verify this for sure?
Old May 15, 2009 | 01:04 AM
Dokken10's Avatar
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
Call your local GM dealer and talk to the parts department and give them that number on your ECM. GM likes to change part numbers for no good reason a lot and when they upgrade a part.
Was this ECM running your 305 TPI with no codes or problems? If not, it will work with a 350 TPI Prom.
86-89 305 TPIs used the 1227165 ECM in F-bodies.
87-89 350 TPIs used the 1227165 ECM in F-bodies.
Old May 15, 2009 | 01:09 AM
Dokken10's Avatar
Car: 91 Formula
http://www.trademotion.com/partlocat...&siteid=213800
If you select chevy then on the next screen click on the P/N it will give you more info about what it fits.
Old May 15, 2009 | 05:09 PM
I called 3 different GM dealers and none of them seemed to have any record of this number existing. I used that website and it told me no more than I already knew, that it would work. Is the 1227165 the ONLY ECM used for 86-89 TPIs though?
Old May 16, 2009 | 01:41 AM
Dokken10's Avatar
Car: 91 Formula
The only one I've ever seen or heard of being in a 86-89 TPI F-body is the 1227165. The Vette ECM is the only other ECM that might work with your engine but it looks different. The ECM doesn't do that much its the Prom that does most of everything.
Is your car with the 305 TPI running good with the ECM you show in the pics?
If so, I believe you are making a big deal out of nothing.
Old May 16, 2009 | 06:10 AM
convas's Avatar
The 86-89 vette also used the 165 ECM, the 88999194 is supposed to be the "improved" replacement for the 165, drop in a 350 prom in it and you should be fine.
Old May 16, 2009 | 08:52 AM
As I had stated to you in a previous thread I bought the car blown up and knew nothing about the running condition of it.
Thanks convas, thats exactly what I was looking for. I knew someone would know this.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
