Infamous Fuel pump driver issue
Old May 19, 2009 | 11:29 PM
AkitaMan's Avatar
Car: 1991 Flaming birdie
Engine: lo3-305 tbi
Axle/Gears: stock
Hello, guys, New to the site, and I just acquired a 91 Firebird 305 tbi. It came with the issue of the fuel pump not wanting to run. The po had wired in a toggle switch to the pump relay and hot wire to get power to the pump so it would run. I found a thread talking about replacing the transistor in the ecm. But, I have to admit, its greek to me. Which one is it in the ecm? And where can I find the replacement transistor, and with what kinda part #? Sorry to be a newb, just not much of an electrical genius. Thanks in advance!
Old May 20, 2009 | 12:27 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Infamous Fuel pump driver issue
You may want to test the output to the relay at the ECM first before assuming its bad. The pin on the ECM that controls the relay is pin A1 (see pinouts below). With the engine running the ECM should provide battery voltage to operate the relay. If it doesent, than its probably easiest to just replace the ECM with another. If battery voltage is present, than it may be the relay itself, or the circuit.
Old May 20, 2009 | 09:22 PM
AkitaMan's Avatar
Engine: lo3-305 tbi
Axle/Gears: stock
Well I tested the Voltage on the pin for the fuel pump driver(dk grn and whitewire) with the car running.It showed 13.8 volts. So obviously it isnt the ecm. I guess the relay is next in line.
Old May 21, 2009 | 10:50 PM
AkitaMan's Avatar
Engine: lo3-305 tbi
Axle/Gears: stock
replaced the relay to no avail. Ended up being the 20 amp fuse at the battery!
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
