How long will it take my custom tuned ecm to calibrate to my engine?
Old Jun 13, 2009 | 01:25 AM
73duster's Avatar
I just installed a 383 crate engine with first fuel tpi setup. The engine is 10.5 to 1 compression with a comp cams high energy 218 duration 484 lift(with my 1.6 rockers) and 24# injectors. It dynoed @ 386hp and 485ftlbs of torque. It also came with a custom tuned ecm that was setup for this particular motor. It is exactly like the stock computer except the chip or (memcal?) was taylored for my setup. I was told by the engine builder that it would calibrate itself and run better after i drove it for a while and should make a little more power in time. The car runs ok except there are a couple of dead spots just off idle at a couple of different rpm points. Sometimes when i let off the brake pedal the car lurches forward and surges as if it wants to accelerate and stop repeatedly. Then i tap the accelerator lightly and it smoothes itself out. It feels as if the fuel map is slightly off a certain rpm's. Does the ecm adjust itself or do i have to have someone tune it. The car sounds great and has a decent chop for the cam, but i hope the throttle response gets a little better. It does'nt feel like it's off by much, how long do i have to drive it around for it to get better? What am i missing?
Old Jun 14, 2009 | 12:25 PM
Drumer919's Avatar
Car: 1995 K2500
Engine: 5.7
Transmission: 4L80E
Axle/Gears: 4.11's
Re: How long will it take my custom tuned ecm to calibrate to my engine?
Its not going to be able to fix that, about the only "learning" it does is of long term fuel trim. You need to get it re-tuned.
Old Jun 15, 2009 | 03:15 PM
Ronny's Avatar
Drumer is right. You should return and allow the Dyno operator to tweek it in those specific areas as needed. All to often the Dyno gets the WOT A/F right but does not spend the time on general drivability area of tune.
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Jake_92RS
Aug 11, 2015 10:39 AM
