87 camaro TPI code 33.. ecm ?
Old Jun 26, 2009 | 12:02 PM
code red's Avatar
After doing A LOT of searching on this site... i found a lot of helpful information regarding code 33.... Used MAF cleaner spray...i checked MAF power, Burn-off, and Fuel pump relays- they're good.... on the harness that goes into the MAF sensor A&B- test light on... D (ignition on-engine not running)- zero volts... C (ignition on engine not running)- 1.1 volts so i checked the B12 on the ecm- got 1.1v
Then i cleared the code and checked MAF harness C- 1.1v and the same at B12 (ecm)... Started the car: B12(ecm)- 3.42v..... let the car warm up to operating temp.. got 3.58v at B12(ecm).. reved the motor at 500 increments upto 2500rpm when down to 3.40v.
is there anything else i should check, maybe the TPS ? Or is my ECM on the way out ?
Thanks, Dan
Old Jun 26, 2009 | 04:09 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Re: 87 camaro TPI code 33.. ecm ?
maybe this will help
https://www.thirdgen.org/forums/post...92-post11.html
Old Jun 26, 2009 | 04:19 PM
code red's Avatar
thats one of the charts that i used that led me to the ecm... i read on a wiring diagram of the ecm- 2.5 with key on and i believe its 4.1 with engine running... as you rev the engine are the volts suppose to increase or decrease...
ftp://ftp.diy-efi.org/pub/gmecm/manu...165v8tpi-6.jpg
Old Jun 27, 2009 | 10:59 AM
code red's Avatar
i tested the B12 (dark green) wire to the MAF harness (c) and got .5 ohms with meter set on 200....trying to search online to see if that is high or low..would this mean an open circuit ?
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
squiggy2
Aug 9, 2015 09:30 PM
