1985 IROC ECM service #
Old Jul 11, 2009 | 12:27 AM
ebrian's Avatar
I have a 1985 IROC Z28 that had a fuel pump failure, I had the fuel pump replaced then the ECM smoked.... I went to the salvage yard to get a new ECM and never paid attention to the service # on my old one..to make a long story short that one didn't work..so I went to Autozone to buy the correct one, and that doesn't work either, I have a different chip for the ECM, BUT that doesn't work either...I think I need to find the service # for the original ECM and start over. It has the 5.0 TPI engine... The fuel pump seems to work through all these changes. I even changed the fuesable link going to the battery. Any help would be GREATLY APPRECIATED!!!!!!!
Old Jul 11, 2009 | 07:56 AM
89F Body's Avatar
Car: 89 z
Engine: 96 350 HSR vortec
Transmission: 700R4 24-2800 BDR stall
Axle/Gears: 9 bolt disc posi w/3.45
Re: 1985 IROC ECM service #
There are 2 #s on the ECM.I have an 85Z ECM I just pulled from my 89Z and the #s are 7-6870 and the DC# is 0706JB.Hope this helps.
BlueIroc-Z's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Axle/Gears: 2.77 posi
Is the "service #" the same thing as the "part number?" According to this it should be 1226870.
Old Jul 11, 2009 | 07:58 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That would be the 1226870 ECM.
RBob.
Old Jul 17, 2009 | 12:57 AM
ebrian's Avatar
Thanks guys for the help with the service #, It looks like I have the right ECM, So I'm back to the fuel pump. I guess I have to to pull the gas tank and see if the guy I had replace the fuel pinched a wire or something....**** I should have just done it myself in the first place....
Thornburg
Aug 25, 2015 01:46 AM
Fronzizzle
Aug 17, 2015 02:52 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
