Engine Cutout After WB Install and BIN Changes
Old Jul 28, 2009 | 05:21 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Since installing the Zeitronix WB and making the required changes to the BIN for open loop running, my engine will cut out every one in a while. When I drive the car for an hour, it might do it 4 or 5 times. If I am at a stop, the engine will usually die. If I am driving, its like I turned the engine off and then back on real fast. The faster I am driving, the less I feel the effects of the cut out.
I was cruising down the highway this evening with the DIAG screen up when it happened (no data log). AFR was in the 14-15 range, I felt the engine cut out (like maybe 1/10 of a second) and looked down st the display and the AFR spiked to 20 and then went back to the 14-15 range after the engine kicked back in. I continued on down the highway.
I had to disturb the ECM and knock sensor under the dash when I installed the Zeitronix controller. I used Velcro and a zip tie to mount it to the ECM. It doesn't seem like a loose wire thing and the ECM is not throwing any codes. Could it be a setting in the BIN causing an issue or could the Zeitronix be creating some electronic interference?
Old Nov 19, 2009 | 03:22 PM
ben73's Avatar
Re: Engine Cutout After WB Install and BIN Changes
The thread is a few months old but I see nobody responded.
My ZT-2 looks at WBo2, RPM, TPS and MAP. It is grounded properly, but every now and then it makes the TPS signal as logged from the ECM go high. I can unplug the ZT-2 and the TPS comes good.. Plug it back in and it reads high again.. Weird.. and annoying.
Are you logging TPS or MAP with the ZT-2?
Old Nov 20, 2009 | 07:29 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
About the TPS with the ZT-2, Dominic was having the same issue. In the end he just disconnected the TPS input to the ZT-2 and left it at that.
RBob.
Old Nov 20, 2009 | 12:52 PM
ben73's Avatar
Thanks RBob, good to know I'm not the only one.
My ZT-2 is at least 4 years old now, I might ask them about this issue and determine if it may have been fixed in a more recent firmware update.
Ben.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
ezobens
Aug 19, 2015 10:29 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
