Ignition map for 383 HSR - MegaSquirtII
Old Sep 17, 2009 | 05:55 AM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
engine: 383 HSR, 34lbs@51psi, 165cc heads, cam duration at 050 inch Lift 224 int./230 exh., running on MegaSquirt 2
i have managed to make my car running but rest is totaly crap. can anybody help me to make base ignition map (12x12), rev is at 6000 rpm.
best regards
Old Sep 17, 2009 | 05:24 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: Ignition map for 383 HSR - MegaSquirtII
I don't think mine would be suitable.
There might be somebody on here that will able to help you.
Anybody running a VE based system with a similar spec should chime in. All he needs are map, rpm, and advance.
Also, map, rpm and VE might be useful for him!
Old Sep 21, 2009 | 05:06 AM
WASyL's Avatar
ok, i see that no body has simmilar setup to mine, but mayb anybody has stock msq file or just stock MSII SparkAdvance table - vex file preffered ??
best regards
Old Sep 22, 2009 | 09:27 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Engine: Turbocharged 5.7 Pro-Fl-XT
Transmission: 700R4 for moment
Axle/Gears: 3.25 9 inch
I should have something that will help. I can get you close to the stock 8D map from a 5.7 TPI. I'll try to get a look at it tonight and see if I can export the table.
Steve
Old Sep 23, 2009 | 02:05 AM
WASyL's Avatar
thats better than nothing, thanks
best regards
Old Sep 24, 2009 | 11:43 PM
ZZ3Astro's Avatar
Car: 87 Iroc
Sorry for the delay.. I've been trying to fight off the swine flu for the past couple of days... Anyway the rpm range is default 700-6000 and goes up to 100 kpa, so not good for boost. Hope it helps!
Probably will have to right click this and save:
http://www.mentalsocket.com/tpitiming.vex
Old Sep 25, 2009 | 02:23 AM
WASyL's Avatar
thanks a milion
best regards
MM2Robinson
Oct 1, 2017 09:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 02:35 PM
355tpipickup
Sep 4, 2015 05:32 PM
