Codes 34, 36, 44
Old Nov 10, 2009 | 11:05 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
Codes 34, 36, 44
Ive done some searching and still cannot seem to the information i need and dont have the option to buy the manual as i am trying to get a transmission in this car and get it on the road. I believe this may have something to do with the MAF but am not sure. The car runs smoothly, no problems but it is VERY fuel hungry!
Thanks for any help!!!!!
Old Nov 11, 2009 | 05:02 PM
inspectorcurly's Avatar
Car: 1992 RS Camaro, 1952 Dodge pickup
Engine: 3.1 and 305
Transmission: Auto Th-350
Axle/Gears: 3:42 in both
Re: Codes 34, 36, 44
According to the friendly Actron Scanner manual
34 is MAF low voltage or MAP low voltage
36 is MAF burn out circuit problems, or trans shift problems electronic trans only, or DIS fault loss of 24X signal or extra missing pulse in the EST
44 is Lean exhaust signal or O2 sensor low voltage or left sensor on dual sensor engine
Have fun these problems are hard without a scanner and book.
Chuck
Old Nov 11, 2009 | 05:06 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
so 36 could be caused by my bad transmission?
Old Nov 11, 2009 | 06:26 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
well just took the car to a friends shop, and the verdict is.....i need a new maf
anyone know if one of another vehicle will work? just to be sure
Old Nov 11, 2009 | 10:51 PM
burnout88's Avatar
Car: 88 IROC
Axle/Gears: 10 bolt 3.73
I highly doubt you need a new MAF. That is typically the response from tech's that are not fimilar with these cars. A bad MAF generally throws a code 33. Replace the three relays on the driverside firewall, MAF relay, MAF burnoff relay, and fuel pump relay and then disconnect your battery to reset your ecm.
This post really belongs in the TPI section you will get more assistance over there. This section is really for advanced programming topics and advanced users. Also, fill out your profile information with the your year, model, engine, etc. Otherwise we cannot help you with such limited info.
Old Nov 11, 2009 | 11:48 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
thanks a bunch burnout for the info, i will do both asap, and keep the tpi forum in mind!
Old Nov 12, 2009 | 10:09 PM
burnout88's Avatar
Car: 88 IROC
Let me know how it goes after you change the relays and I will give you some other things to check.
Old Dec 27, 2009 | 04:34 PM
ikeepitreelz's Avatar
Car: 1988 gta-
Engine: 383 tpi
Transmission: 700 r-4
I must agree with the other poster, When my Ses light came on the car ran rough and code 36 developed, i changed both the MAF power Relay (Part MR22) and the burn off relay at Auto Zone. I only ran the car for like 30 minutes but it def. felt different,beats buying a new MAF (about $210) at Auto Zone. The car has also code 44 but this might be because code 36 triggered it. Hope this helps somewhat
Old Jan 13, 2010 | 11:10 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
code 36 won't trigger code 44.....33 and 34 could thought because the A/F ratio will be off thus causing the O2 sensor to read rich for too long or lean for too long causeing an O2 fault.....but yes this does belong in the TPI section
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
