idle issues
Old Nov 16, 2009 | 12:40 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
idle issues
lately ive noticed that if i start my camaro up and dont touch the throttle at all for an extended time (1-2 min) it starts getting "confused"
what i mean is that it seems to loose the ability to keep a stable idle.
normally it idles right around 650 rpms just fine, but after awhile, it starts jumping between ~500 and ~750.
it will usually be from 500 to 750 and back in about 1.5-2 sec.
if i touch the gas or put a load on the engine it smooths back out.
if i let it go, it will get a bit worse then get better and stop altogether for a while only to start again later.
it does it warm and cold
anyone know what could possibly be the cause of this and what i should do to remedy this?
ive already tried to adjust the IAC motor and it seems to help the general idle quality but since i had never noticed the problem before, i cant say if it helped at all with the surging.
if i raise the idle up with the stop screw in the throttle body to about 750 or so, it wont do it nearly as bad if at all.
to me it seems like the computer/IAC motor cannot react fast enough and is getting caught in a YO-YO motion until i step in and tap the gas
Old Nov 17, 2009 | 09:06 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
Re: idle issues
would this be better in the tech/general board?
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
