TPS is messed up
Old Nov 16, 2009 | 03:16 PM
sscamaroracer87's Avatar
Car: 87 Camaro ss
Engine: 252 V6
Transmission: Manual 5-speed
Axle/Gears: rear wheel drive and factory gears
TPS is messed up
I have a 1987 2.8L V6. It is the MPFI model engine. My TPS (throttle positioning sensor), Is way off. I hooked up a volt meter to it and it said 2.1 for idol. It is supposed to be at 0.5 to 0.7 on idol, and 4.5 to 4.7 at full throttle. I do not know how to adjust it. Please reply with answers
Old Nov 16, 2009 | 09:53 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TPS is messed up
The adjustable TPS have slotted holes for the mounting screws. Loosening the two screws will allow the TPS to be moved for adjustment.
However, being at 2.1V is a far way off. It may be that the TPS is bad. Try adjusting it first, but if it doesn't cooperate then best to replace it.
RBob.
Old Nov 16, 2009 | 10:22 PM
y84pauloflondon's Avatar
Car: 87 T-Top GTA
once you loosen your tps (2 screws, top and bottom) you can turn it like a dial. Turn it clockwise and counter clockwise is how you adjust it. Just like RBob said, play around with it and see what changes, if not by much, then replace it!
OH, and it should be on a V6 engine set at 0.35v to 0.67v! get it halfway in between, something like 0.50v-0.53v. 0.35v will run lean and 0.67v will run more rich.
V8's are set at 0.46v - 0.62v, FYI.
Old Nov 16, 2009 | 11:43 PM
Car: 87 Camaro ss
Engine: 252 V6
TPS is messed up
It is a brand new tps. I loosened the two mounting screws and it adjusted 2.1v to 3.6 volts on idol.I have a 1987 2.8L V6. It is the MPFI model engine. My TPS (throttle positioning sensor), Is way off. I hooked up a volt meter to it and it said 2.1 for idol. It is supposed to be at 0.5 to 0.7 on idol, and 4.5 to 4.7 at full throttle. I do not know how to adjust it. Please reply with answers
Old Nov 17, 2009 | 04:40 PM
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
if i remember right its sapose to be .54 volts closed. have to loosen the bolts and rotate up/down to get right voltage.
Old Nov 17, 2009 | 05:35 PM
hawkdriver's Avatar
Car: 87 GTA / G8 GT
Engine: 5.7L / 6.0L
Transmission: auto's :(
.54 closed and over 4.0 at WOT
Old Nov 17, 2009 | 06:23 PM
Car: 87 T-Top GTA
Does any have a pic of a disgram to show? The 4 of us have already told sscamaroracer87 how to adjust the TPS and He/She is not getting it!
sscamaroracer87 might have the multimeter on the wrong setting! I've set mine before, but I CAN'T remember what the proper setting is!(Measurement).
Other then that, I don't know what else to say/tell!
Old Nov 19, 2009 | 08:21 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
the sensor should look like that have elongated holes that the screws go into, losen the screw slightly and turn the black plastic clockwise or counter clock wise
F-body-fan
Jan 12, 2023 01:49 PM
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
