305 to 383?
Old Nov 22, 2009 | 03:29 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
305 to 383?
I have a 85 305 tpi and im putting together a 383, I guess im just confused on what type of ecm I would use. From my understanding the 85 ecm is junk. I plan on using the new BBK TPI intake (comes out this spring) that uses the stock fuel rail and harness. Would i need to replace the whole harness and ecm or can i just replace the ecm with a later model 350 ecm? I plan on supercharging on a later date, should i use SD or stay with the MAF?
Old Nov 22, 2009 | 04:03 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 305 to 383?
I'm not going to get into the MAF vs. SD debate. However, here is a link to a site where the owner did the '85 ECM to a '86-89 ECM swap. Then went from the '85-89 ECM to a SD '90-'92 ECM:
http://www.eecis.udel.edu/~davis/z28
Lots of good information on that site. He also put together the info for each swap along with a bunch of BINs, pictures, and other tests.
RBob.
Old Nov 22, 2009 | 04:19 PM
robbyk85's Avatar
Car: 85 iroc
Engine: 383
Re: 305 to 383?
I understand the differances between SD and MAF, I guess the question was more about would supercharging still work if it was MAF system or would I have to swich to SD. Maybe it would work for both setups I dont know. Thanks for the site it should be really helpful.
mhatfield 14
Oct 24, 2015 07:48 AM
angel2794
Sep 8, 2015 06:22 PM
gixxer92
Sep 1, 2015 04:32 PM
5spdcamaro
Aug 28, 2015 02:12 AM
bdads
Aug 24, 2015 06:01 PM
