vette - Bird prom swap
Old Dec 19, 2009 | 10:46 AM
budfreak1's Avatar
Car: 1991 Trans Am GTA
Engine: 355
Transmission: 4L60
Axle/Gears: 4th gen 10 bolt 3.42 posi
Can a prom chip from a 1991 Corvette be swapped into the computer in my 91GTA? I ask because I found a performance chip for sale for a 1991 350 auto Corvette, and I'd like to buy it if it will work in my 350 auto GTA.
Thanks in advance for any input.
Old Dec 19, 2009 | 12:50 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: vette - Bird prom swap
Yes & no. You can use the PROM or MEMCAL from the Vette in your car. And it will run.
However, it is not a direct replacement. The SES will be on as your car doesn't have an oil temperature sensor that the Vette engine has. The fan(s) may be inverse where they run when the engine is cold, and off on a hot engine.
The biggest issue is that the Corvette has '113 aluminum heads vs. your car having iron heads ('093?). So the timing tables will be all wrong.
RBob.
Old Dec 19, 2009 | 12:53 PM
budfreak1's Avatar
Engine: 355
Transmission: 4L60
Understood, I didn't even think about the heads. Thank you for the reply.
Old Dec 20, 2009 | 08:13 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
How much is the prom?
Even if the programming on it is junk, these memcals are getting hard to find. They used to go for like $45 new years ago, now guys are asking a premium.
My point is, if it's cheap enough, it might be worth it as a spare memcal.
-- Joe
Azrael91966669
25
Jun 20, 2017 04:04 AM
Keith5
Aug 27, 2015 04:37 PM
hokis
Wheels and Tires
Aug 26, 2015 04:21 PM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
