code 12 c.e light on
Old Jan 4, 2010 | 01:58 PM
thetaman85's Avatar
Car: 85 Firebird Trans Am
Engine: Rebuilt 305 Carb
Transmission: Built 700R4
Axle/Gears: The unfortunate Open Diff, 3.23
i have an 85 t/a 305 tpi and every once and a while my check engine light comes on and the car idles about 600 rpm high and only when the light is on. i flash the code and the code 12 keeps flashing. code 12 reads no reference pulses to ecm. could it be my ecm is bad or could it be somthing like my tps?
thanks
Old Jan 4, 2010 | 02:11 PM
Twin_Turbo's Avatar
Re: code 12 c.e light on
check the est bypass connector first, it may be loose and causing the check engine light to go on. the connector is located in the wiring that runs along the firewall above the heater box
Old Jan 4, 2010 | 02:17 PM
thetaman85's Avatar
would it change anything by mentioning somthing i forgot about, a few weeks ago my light gave me a code 44 it did it again about a week and a half later i have the oxygen sensor but have not had time to replace it could it be the same problem or the o2 sensor or the ecm?
thanks
edit: just chacked the connection you spoke of and it all looks good.
Old Jan 7, 2010 | 04:26 PM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
code 12 is always there, it just means the motor is not running ( no signal from dist.) I would change O2 and check the conector at O2 also.
chazman
Aug 28, 2018 03:25 PM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Omega
Aug 10, 2015 12:46 PM
