Need memcal interchange
Old Feb 14, 2010 | 08:00 AM
JoeK18's Avatar
Car: 1991 Camaro RS 1953 Chevy Bel-Air
Engine: 305 tbi and 283 Eddlebrock
Transmission: 5 speed std. 700R4
Axle/Gears: forgot?
Hi everyone, this the first time I'm using this. It's really cool! Anyway, I'm planning on using a TPI off a 85 or so Camaro for my 48 Chevy street rod. I have a 4bolt 350 out of a Chevy truck (actually camper), stock. Every week end we go to the local U pullit yard and try to get all the parts we need for this setup to work. I just got a ECM out of a 92 Camaro (7730), only it was a six cylinder (all I can find). I know how to cut out the chip and I have a programmer to make a new one, but do I understand that the other part of the memcal that senses the knock sensor will not work with a 8 cylinder? If so, does anyone know what will interchange? Trucks and vans dont have a memcal like the 7730. What does? Caprice? Roadmaster? Any ideas?
I have the capability of making my own harness, no problem, and plan on a speed density system for simplicity. Not entirely sure of some details, like should I use VSS, I am running a 700R. I dont need vats, I'll delete that. Also, if the OX is to far from the engine (headers) I hear I can use a 4 wire OX with a heater in it to assure it's hot enough.
Sorry to ramble on, lots going on with this setup. Any info is surely appreciated! Thanks for reading. Joe Kandrot
Old Feb 14, 2010 | 08:35 AM
witnlyn's Avatar
Car: 54 Chevy Sedan Delivery
Axle/Gears: 3.73 posi
Re: Need memcal interchange
you will need a memcal from a tpi car,check out this site it has a break down of memcal id http://www.chevythunder.com/
scroll down to prom BCC codes tpi 90-92
Old Feb 14, 2010 | 09:18 AM
JoeK18's Avatar
Axle/Gears: forgot?
Thanks, I'll check it out. Hey, I got a '53 custom coupe. 283, 700r. No tpi, but I wish it did. Whats is your 54. ?Someday.
Old Feb 14, 2010 | 09:23 AM
witnlyn's Avatar
54 is still a work in progress, got it running but still a lot of work to do on it.
Old Mar 2, 2010 | 05:43 PM
scuzz's Avatar
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
TPI in streetrods used to be good marriage.
Now, TPI SD memcals are really hard to find.
I've done a TPI in 37 Chevy sedan, 40 Chevy coupe, 35 Dodge sedan, 58 Vette and a 67 Firebird convertible.
They really make an old car a smooth runner.
You might want to look at the TPI with OBDII changeover now for ease of parts in the future if you plan on keeping the car. There's an article in the DIY section.
The 41 pickup I'm doing now is Ramjet with OBDII changeover. I plan on driving it as long as I can drive.
88SS6SPEED
Nov 11, 2015 07:05 AM
lethaldomestics
Sep 21, 2015 01:18 PM
sbrandon
Sep 9, 2015 07:31 AM
