Disabling knock sensor
Old Feb 15, 2010 | 03:50 PM
Mastiff's Avatar
I have no knock sensor hooked up on my vehicle (TBI 7747). If I try to run an unmodified bin, what happens? Does it think it's knocking all the time (and retard the timing), or never knocking?
Old Feb 16, 2010 | 07:25 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Disabling knock sensor
With no sensor, but with the filter still in place it won't do anything. IIRC, everything looks OK.
With no sensor and no filter it will continuously report knock, toss code 43, and pull a set amount of timing all of the time.
RBob.
Old Feb 16, 2010 | 09:14 AM
Mastiff's Avatar
Is the filter the external "knock computer" under the dash? In my case the harness doesn't even have a provision for knock. Is it difficult to mod the bin to not do the knock retard? Thanks for the help.
Old Feb 16, 2010 | 12:00 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The knock filter is under the hood or under the drivers seat with the ECM. For the BIN just zero out the two max retard tables, and/or, set the knock enable CTS temperature at it's maximum value.
RBob.
L98GTA87
Oct 19, 2015 10:43 PM
cking99
Sep 22, 2015 11:33 AM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
BLK87Z
Sep 18, 2015 11:29 PM
FormulasOnly
Sep 10, 2015 09:07 PM
