Memcal difference between T5 and 700R4?
Old Feb 17, 2010 | 11:30 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I'm about to order an Ostrich 2 from moates, and I'm a little confused about the G1 adapter. It looks like it plugs in where the memcal goes, and then the ostrich connects to that, right? But then the limp-mode circuits are no longer in place, so what happens if the ECM tries to go to limp mode? I have a spare memcal, but it's for an 88 LB9/700R4. I'm thinking it might be better if I modify that one by adding a ZIF socket, and just plugging the ostrich into that. But is there any difference in the limp mode circuits between the T5 and 700R4 memcal?
Old Feb 18, 2010 | 12:32 AM
supermariobros's Avatar
Car: 89 Formula TPI
Engine: LB9
Transmission: WC T5
Axle/Gears: 3.73 posi locker ls1 discs
Re: Memcal difference between T5 and 700R4?
I did a swap to t5 and didn't touch the computer and the car runs fine
Old Feb 18, 2010 | 07:02 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The MEMCAL plugs into the side of the G1 and retains the the two CALPAKs and knock filter (if present).
RBob.
luvofjah
Sep 26, 2015 08:28 PM
6998poncho
Sep 25, 2015 02:56 PM
HikoriYami
Sep 21, 2015 07:11 PM
lethaldomestics
Sep 21, 2015 01:18 PM
