Have searched,Don't understand?
Old Mar 28, 2010 | 02:47 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
Transmission: th700r4
OK, I'm getting my car ready for summer driving. 1991 z28 5.7 tpi 700r4. I replaced the fuel pressure regulator (adjustable now), EGR valve, and coolant hoses this winter. Today I took her out for a cruise after a 20 minute warm-up. And at about 3 miles of highway driving (65 mph) the SES light came on. The car seemed to be running great at the time. I took it home and read the codes and came up with code 12,speed reference pulse, and code 32 EGR failure. What did I do wrong, and how do I fix it? You people have helped me more than you could know in the past and I would really appreciate it now. Thank's Randy Almost forgot, fuel pressure at the regulator drops to 0 in lrss than a minute, no leaks or fuel smells that I can sense.
Old Mar 28, 2010 | 07:19 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
Re: Have searched,Don't understand?
is it possible that either your EGR stovepipe(s) or the passage into the intake is plugged with carbon? if so, that could do it.
Old Mar 29, 2010 | 05:19 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
I was hoping that wasn't the answer but it probably is. Thanks for the help! I still don't understand the code 12 though.
Old Mar 29, 2010 | 05:31 PM
Saar's Avatar
Car: 1985 IROC-Z28
Engine: LB9
code 12 is what flashes to let you know the ECM is working and sending out a flash pattern for the trouble codes.
Old Mar 29, 2010 | 06:26 PM
STEWARDORNG's Avatar
WE HAVE THE SAME CAR AND HAD THE EGR CODE THE OTHER DAY THE ONLY THING WRONG WAS THE VACCUM HARNESS HAD CAME LOOSE.
Old Mar 30, 2010 | 05:13 PM
randyz91's Avatar
Car: 1991 z28
Engine: 5.7 tpi
thank's for the help, I followed your advice and I think I got it right now, randy
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Ron U.S.M.C.
Sep 7, 2015 08:38 AM
355sbcTPI
Aug 19, 2015 04:38 PM
kyleb24
Aug 15, 2015 08:24 AM
